Thread: Trimming Lines.
    Default Trimming Lines.
    Thanks Robert B for the answer on the Leader Line Question.
    Here is another frequent occurance with ACAD2008. Trimming of lines with an Xref behind it. Not sure if it is because of the Xref , but when I try to trim lines quickly, AutoCAD2008 crashes. It happens too often in our office just to say "it was an accident". Cheers and thanks. ps. I also have issues with the "unreconciled layers message". was that really something we needed?
    2008-03
    383
    Default Re: Trimming Lines.
    Quote Originally Posted by stirx View Post
    I had an experienced having that issue of cad crashing what I can suggest is try draw- ordering the xref back so your lines will be on top; Unload the xref when you are still experiencing that issue before trimming some lines; Clean the xref, it might be the cause when your xref is huge (has unresolved child xref); try extend trim (extrim command).
    For the reconciled layers try this sites:
    http://www.augi.com/publications/hotnews.asp?page=1583
    http://forums.augi.com/showthread.php?t=73734
    and if you decided to purge it try this from JTB:
    http://blog.jtbworld.com/2007/04/pur...mation-in.html
    Thanks Archie.manza.
    You can guess what I will do as soon as I get out of this thread.
    Cheers
    ps. edit.
    I just emailed the answer on reconciled layers to my 200 odd colleagues in our company. Your reply became an instant success. Perhaps AutoDesk should do a rethink and not make it a Default but give us the option. Thanks A.m
  1. Trimming lines inside Boundary and deleting others
    By sunsat05463998 in forum VBA/COM Interop
    Last Post: 2012-01-20, 04:46 AM
  2. Trimming multiple lines in AutoCAD LT 2005
    By vince.lam in forum AutoCAD LT - General
    Last Post: 2008-04-17, 12:27 PM
  3. Create Hidden Lines when Trimming
    Last Post: 2007-08-30, 08:05 PM
  4. Picked lines in sketches not splitting or trimming?
    By cosmickingpin in forum Revit Architecture - General
    Last Post: 2006-03-08, 09:52 PM
  5. Trimming Detail Lines in Legend Views.
    By beegee in forum Revit - Known Issues & Work-Arounds (Read only)
    Last Post: 2005-06-08, 07:28 AM
