Results 1 to 10 of 10
Thread: Model space xref layers
    2006-02
    39
    Default Model space xref layers
    Hi,
    How do I access only the model space xref layers?
    Thanks
    2007-07
    104
    Default Re: Model space xref layers
    This is a way to get their names. Don't know exactly what you want though.
    Public Sub ModelXrefs()
    Dim Entity As AcadEntity
    For Each Entity In ThisDrawing.modelSpace
    If TypeOf Entity Is AcadExternalReference Then
    MsgBox Entity.Name & " is an xref, inserted on layer " & Entity.Layer & vbCrLf
    End If
    Next
    End Sub
    2006-02
    39
    That's good. But how do I get the nested xref layers?
    2007-07
    104
    Command: LAYWALK
    Select the xref
    2002-02
    Kansas
    487
    The same way you get to the other layer the xref layer name will be the XrefName|layername
    exp: if the xref name is xxx and has a layer name zzz the the layer name will be xxx|zzz
    note: The 0 layer for xref will be layer 0
    so if you need to get the xref layer, loop thru the drawing layer and get the layers that have the | in them
    Note:
    update to 2011
    I am using ADT 2007 08/06/2008
    PS. If you use any Code I post or Down Load Attachment I would like to know if it was helpful. So please post reply to this thread, on how you use the code or down load. Thank You
    Member jason.bell's Avatar
    2008-02
    New York
    29
    The following will list the xref layer names on the command line. is this what your trying to do?
    Sub xreflayprint()
    Dim xrefname As String
    Dim layname As String
    Dim i As Integer
    Dim ent As AcadEntity
    For Each ent In ThisDrawing.ModelSpace
        If TypeOf ent Is AcadExternalReference Then
            xrefname = ent.Name
                For i = 0 To ThisDrawing.Layers.Count - 1
                    layname = ThisDrawing.Layers.Item(i).Name
                    If InStr(1, layname, xrefname) > 0 Then
                        ThisDrawing.Utility.Prompt layname
                        ThisDrawing.Application.ZoomExtents
                    End If
                Next i
        End If
    Next
        ThisDrawing.Regen acAllViewports
    End Sub
    2006-02
    39
    Quote Originally Posted by jason.bell View Post
    Sub xreflayprint()
    Dim i As Integer
    xrefname = ent.Name
    End If
    Next i
    End If
    Next
    End Sub
    That does the work. But what about the nested xref layers?
    2006-02
    39
    Quote Originally Posted by jwanstaett View Post
    I tried the method you mentioned. But it retrieves the xref in the layout too. I need the xrefs only in the model space.
    2007-07
    104
    I suppose you could make jason.bell's program ask for an extrenalreferenece within the externalreference.
    2006-02
    39
    Thanks darfnuggi. I solved it.
  1. Replies: 2
    Last Post: 2014-02-18, 01:25 AM
  2. 2010: XREF block visibility states & Batch plot on Model Space
    By Buh in forum AutoCAD General
    Last Post: 2013-08-23, 11:10 AM
  3. Replies: 0
    Last Post: 2011-10-21, 06:44 PM
  4. xref in model or paper space?
    By cadprog in forum VBA/COM Interop
    Last Post: 2008-07-24, 04:16 PM
  5. Replies: 3
    Last Post: 2006-09-22, 08:22 PM
