Thread: Contours
    2002-06
    Winnipeg, Manitoba, Canada
    109
    Default Contours
    I am new with Civil 3D, and I am doing OK with it.
    I generated a topograhy layout for a land drainage plan and activated the contours. I need to show the water ponding areas. I want to "trace" over a contour to get the area so my enginer can figure out the volume. Is there a way of isolating or extracting the contour(s) required for my purpose? I cannot snap (other than NEAREST) to the contour.
    Thanks.
    Ted
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Contours
    Surface -> Utilities -> Extract surface data.
    You may also want to look into the pond stage storage extension, which I believe is available as a download from the subscription center (i.e. for subscription customers only).
    2002-06
    109
    PERFECT!
    Thanks, sinc.
  1. GIS Contours
    By rschaff in forum AutoCAD Civil 3D - General
    Last Post: 2010-10-08, 10:08 PM
  2. Contours
    By spaynter08 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-03-27, 02:13 AM
  3. Not able to see contours
    By msanders.85217 in forum AutoCAD Civil 3D - General
    Last Post: 2006-05-04, 08:06 PM
  4. Contours
    By chrisr in forum ACA General
    Last Post: 2005-02-12, 10:04 PM
