Results 1 to 6 of 6
Thread: Level and Grid lines -> Send to Bottom
    2008-07
    Brisbane (Ex. Swedish)
    349
    Default Level and Grid lines -> Send to Bottom
    Hi,
    Is It possible to have the Grid and Level Lines "moved" to the bottom i.e. they are not printed on top of everything ells? I think I read something about this somewhere ells and if I recall it correctly you can't - I guess I just want it confirmed by the gurus on this forum.
    Cheers
    J
    2002-02
    St. Louis, MO
    4,695
    Default Re: Level and Grid lines -> Send to Bottom
    There is no such setting for level and grid lines.
    You can only edit the extents and pull them back from the building if you don't want them going over geometry.
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Grid lines in 2009 can contain gaps.
    2008-07
    349
    I have set our grid lines to have a grey colour so they are not standing out to much (I guess this comes from how we have our Grid Lines set up in Autocad).
    On 1:100 Layout for example they are printed on top of the geometry. See attached images. The obvious workaround is to use a thinner pen and not use grey as the line colour.
    Cheers,
    J
    2008-02
    115
    Quote Originally Posted by jeffh View Post
    Very cool! Thanks for pointing that out Jeff. That'll teach me to sit through and read the new features workshop someday....
    - Jon
    2013-04
    21
    We simply add a general note to each plan sheet:
    Note:
    All instances where walls appear to be missing, contractor to actually provide a real wall. Owner to confirm with Autodesk prior to construction of actual invisible walls.
    Quote Originally Posted by kingjosiah View Post
    - Jon
  1. Door in bottom grid of sloped curtain wall
    By stevomatic in forum Revit - Platform
    Last Post: 2009-04-29, 10:09 PM
  2. Construction Grid Lines and Grid Dimensions..angles columns
    By persianize in forum Revit - Student Support
    Last Post: 2009-01-02, 10:52 AM
  3. Grid and Level lines are drawn on top of objects
    By johk in forum Revit - Platform
    Last Post: 2008-03-12, 08:55 PM
  4. Wall Layer Top and Bottom Offsets to Level
    By Scott D Davis in forum Revit Architecture - Wish List
    Last Post: 2005-06-24, 04:08 PM
  5. Grid Head / Grid lines on separate export layer
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-10, 10:02 PM
