Results 1 to 6 of 6
Thread: Pads Pads Pads...oh and there's a problem
    2006-08
    10
    Default Pads Pads Pads...oh and there's a problem
    I'm trying to create two sloping pads abutting one another and when finished they leave a tiny sliver of topo surface between them. The sketch lines for the pads have all been aligned properly, and yet I still get a "gap" between them. Any ideas?????????
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Default Re: Pads Pads Pads...oh and there's a problem
    You could try reversing the head/tail of the slope arrows on the slabs. I seem to remember this issue and a reversal of the slope arrows resolved the problem.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    2006-08
    10
    Reversing the slope didn't fix the problem. I tried editing the surface and defining elevation points to get it to work but it still showed the sliver in question. Looking closer at the issue, the slivered topo surface does not reflect the original topo I had associated the pad with. It's consistently about a foot higher. I can hide the element within views but it also hides the surface's poche in any section views.
    Now I'm really stuck...
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    Question Re: Pads Pads Pads...oh and there's a problem
    kms,
    Can you post the example?
    cheers...
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2011-07
    23
    kms, here's the exact explanation you need:
    http://revitoped.blogspot.com/2009/0...pe-arrows.html
    It works.
    2004-06
    Memphis TN area
    7,047
    OMG wow, and this whole time I thought this was a bug with versions prior to 2012. Wish I had known about this on the last 2 projects I had with sloping pads!
    I believe this issue is related to the Height Offset from Level setting being different for each pad. Since that setting is a different elevation for each, it places that sliver between the 2 pads even though the "higher" pad slopes down to meet the lower pad. If you place both pads at the same level and slope one of them up, the problem goes away.
    AERC, PLLC
    Hernando, Mississippi
  1. 2011: Problem with curved sloped pads
    By lucasnguimaraes in forum Revit Architecture - General
    Last Post: 2012-03-27, 05:36 PM
  2. pads....
    By ntnik in forum Revit Architecture - General
    Last Post: 2008-11-28, 04:09 AM
  3. Problem with toposurfaces and pads
    By dpasa in forum Revit Architecture - General
    Last Post: 2007-01-29, 07:01 AM
  4. Phasing problem with topography and pads
    Last Post: 2005-10-20, 02:14 PM
  5. Problem with Pads and linked RVT
    By rgranja508683 in forum Revit Architecture - General
    Last Post: 2005-03-03, 05:18 PM
