Help,
I've been searching for an answer for 2 months and just cannot find the right information.
Our company uses upto 60 layout tabs (paperspace) in each drawing. We want to use fields to automatically update the title block information and sheet labels. Some of the information is sheet specific. Some of the information is drawing specific. If we try to use sheet properties for a template, we lose the information.
1. If we copy the dst file (or archive, or e-transmit) and rename it, the sheet associations break down. We can re-link them one at a time but that takes almost as long as just manually updating each sheet which defeats the purpose of using fields.
2. If we create a new sheet set from a template, we lose the layout data which contains the fields we aer trying to avoid recreating each time.
We are used to havuing a master template drawing that we copy and rename when we start a new project and then just update the relevent data on each sheet.
I cannot seem to find a way to preserve the layout structure and fiel associations without copying the template DST file to a new folder and then keeping the name Master_SS_Template (or whatever). As soon as we rename it all is lost.
a. Is there a way to reassociate all of the sheets in the set automatically to the new drawing file in the new folder, preserving the structure?
b. Is there VBA script that can do the updating, When the files are copied and renamed the only thing that changes is the filename. IE..
from Master_Template. dwg and Master_Template.DST
to Job12345.dgw and Job12345.dst
We are naming our layout tabs usinf the following convention:
01 Drawing Index, 02 Vicinity map, 03 Site Map, 04 Facility Map, 05 Facility Elevations, 06 Facility Plan, 07 Facility Details, etc... to "60 whatever" or more
We use the numerical prefix for automated sorting and renumber after adding additional sheets when needed. It also helps sort the sheets in the SSM (I'll have to find an automated way to do that one day as well).
We deal with many military and governent customers and cannot change our drawing package format easily so I really need to find a way to get things working with our current scheme if possible.
Help! What Can I do? How can I create a new file that is a dupliate of the template file complete with valid links and associations except with different filenames. There are no external references used. The title block is a block within the drawing.
Most of the fields come from the drawing properties:
project name, project location, project manager, project engineer, draftsman, description, revision, file location.
I want to pull the drawing number, sheet description, and sheet number from the SSM and maybe custom properties.
Can anybody steer me in the right direction?
Buddy Brooks
CAD Engineer / Designer
