Thread: Level Annotaion Issue
    2008-10
    6
    Default Level Annotaion Issue
    Early in the project I had deleted the 2nd Floor level in Elevation thinking I wouldn't have a need for multiple floors. Well, the client has decided to put ina 2nd Floor. So now I still have a 2nd floor referenced but I cannot show a 2nd Floor symbol in elevation or section. When i try to place/rename a symbol as 2nd floor @ 12'-0" it says the level already exists. Is there any way to replace a level tag after deleting it?
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Question Re: Level Annotaion Issue
    See if there is a 2nd Level Floor Plan View in the project browser, and delete it.
    Now, see if the "mystery" level is now gone--it should be.
    Then, go to an elevation view, and place a new Level, name it Level 2, or whatever.
    Did this work?
    ( I don't think it is possible to replace only the annotation for a Level.....)
    cheers.
    2008-10
    6
    Default Re: Level Annotaion Issue
    hmm... So if I delete the Level Annotation in elevation, there is no way to "tag" the existing level with another level annotation? There has to be a way to relabel a level...
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Level Annotaion Issue
    Think of it like this:
    The Level Annotation IS the Level--i.e. it is an intelligent BIM object, not purely
    a 2D annotation, as in other cadd software.
    Cheers...
    All AUGI, all the time Gadget Man's Avatar
    2004-10
    Sunshine Coast, QLD, Australia
    607
    In fact, the views in the browser refer to the LEVEL objects in the model - not the other way around. So, you can have several VIEWS referring to one LEVEL object but you can't have one VIEW referring to several LEVELS.
    So, you can delete all the VIEWS referring to a particular level and that level still exists.
    However, if you delete a level - I think that the view with the same name is removed too (I am not in front of Revit now, so I can't check it at the moment) and some other view of the the views referring to that level may adopt its name (e.g. a ceiling plan view).
    This may be a reason for an error (the name already exists) when you try to re-introduce a level and automatically assign the level's name to the newly created view.
    I hope it makes sense what I tried to explain...
  1. 2015: Annotaion Family Object Style
    By mit81 in forum Revit MEP - General
    Last Post: 2015-07-16, 01:02 AM
  2. 2015: How to solve <no level> issue ?
    By dedo81675295 in forum NavisWorks - General
    Last Post: 2014-07-01, 09:28 AM
  3. Annotaion Pen Settings
    By gra77 in forum Revit MEP - Families
    Last Post: 2012-02-21, 02:18 AM
  4. Annotaion Scale during plotting in Paper Space
    By odwa.noah in forum AutoCAD Annotation
    Last Post: 2008-02-29, 03:33 PM
  5. level issue....
    By ntnik in forum Revit Architecture - General
    Last Post: 2007-05-24, 02:31 PM
