Thread: Unfilled fonts in PNG files
    2004-01
    3
    Default Unfilled fonts in PNG files
    I am working with a company where I create 2D drawings and then create PNG files using LT2004. All goes well until the comapny opens one of the drawing files and then creates another PNG. The issue is that the fonts are shown UNFILLED (verdana) as apposed to correctly being solid. The comapny is using a network version of AC2002. Note that on another company computer using a stand-alone version of 2002 this doesn't seem to happen. Also, if the drawing was created in 2002 versus 2004LT (saved as a 2002 file), the problem doesn't seem to arise.
    Any suggestions? Thanks in advance, Doug
    2015-12
    Arizona
    2,478
    Default Re: Unfilled fonts in PNG files
    on the suspect machine check your settings for
    TEXTFILL and FILLMODE
    2004-01
    3
    Quote Originally Posted by mjfarrell
    Thanks Mike, problem solved!
  1. Fonts in Linked CAD files
    By chrisl.224505 in forum Revit MEP - General
    Last Post: 2010-11-17, 03:41 PM
  2. Interior Elevation symbol with unfilled arrows?
    By ron.sanpedro in forum Revit Architecture - Families
    Last Post: 2007-05-02, 11:55 PM
  3. Replies: 5
    Last Post: 2007-03-16, 12:02 PM
  4. Unfilled Polylines in Perspective View Layout
    By jsweene in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-01-28, 07:54 AM
