Thread: Cross Sections in Plan Production
    Wish List Administration
    2007-08
    434
    Default Cross Sections in Plan Production
    Summary: The ability to generate cross section sheets using Plan Production.
    Description: Improvement (more automation) in cross section plans production whereby similar automation as applied to plan and profile layout generation is also shared by cross sections.
    How Used: Currently several methods can be used to create the layouts for cross section views into Sheet Set Manager (see: https://www120.livemeeting.com/cc/autodesklearning/view?id=Civil_RO-78&pw=Audience&cn=) but are difficult and very tricky to set up. These methods do not share the same level of automation as plan views or profile views (in the View Frame Wizard and Create Sheets Wizard). I would like the Wizards to also handle cross section plans production as well.
    Feature Affinity: Plan Production
    Submitted By: Bruce Dana on October 17, 2008
    Member ittybittyd's Avatar
    2003-08
    Alberta, CANADA
    10
    Thumbs up Re: Cross Sections in Plan Production
    Yes! I REALLY need to be able to efficiently plot ALL cross-sections on the project to one PDF file; one cross-section per page (or perhaps multiple per page as an option). This should include the ability to specify page size, ie. 8.5x11, 17x11, 8.5x14, 34x22 and various scales as required to include the limits of the cross-sections. The output device should include several options, ie. .pdf, .plt, .dwg, straight to printer, etc.
    Many projects can include up to 700 cross-sections, ie. a 14 kilometre highway project with a section every 20 metres so we need an efficient automated method! I would also use this tool for other collegues to review designs.
    Donna
    ____________________________
    WE CANNOT DIRECT THE WINDS,
    but we can adjust our sails.
  1. Create multiple Plan views per sheet using Plan Production Tools
    Last Post: 2013-11-05, 11:24 AM
  2. CV204-4: Sections: From Plot-by-Page to Plan Production
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:25 AM
  3. Plan Production Multiple Plan Views per Sheet
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-06-02, 06:51 PM
  4. Cross Sections in Plan Production
    Last Post: 2007-10-01, 07:36 PM
  5. Cross Sections sheets generated like Plan/Profile
    By ramon_tavarez in forum Civil 3D Wish List
    Last Post: 2007-08-22, 02:36 PM
