I'm using ACAD 2009 Full
Last week I still using ACAD 2009 as normal, but today I totally cannot ACAD 2009
Anyone know why? How to solve this problem?
thanks
Jack Cheong
thanks
Jack Cheong
There is a lot of possibilities here. First is, are you in the company that restricts some user using some program? Like in our company, some may have access on Autocad 2008 but some may not. I think this is an issue that you had to ask your IT.
Have you tried repairing it? Open control panel and click repair. Also, it might be your Anti-virus that blocks Autocad from opening. As for what have you said that you have been using this before, so there's no way that it is an Admin user issue (right-click on Autocad Icon then run as Administrator). I had check the Description of the Autodesk Update 1 & 2 on Autocad 2009 and there are no issues like this. Other than that nothing else I can help you with.
I already turn off all Anti-Virus software, but still cannot startup ACAD 2009
But when I startup ACAD 2007, below message appear:
"Unhanded Exception C0000005 (Access Violation Reading 0x0000) at address 0h"
After I click OK, it still work as normal, only everytime I start the software, the same message appear again
Jack Cheong
I try to search it on Autodesk and this is what I've get - Try this it might be the same issue with you. http://usa.autodesk.com/adsk/servlet...linkID=9240617
