Thread: Standard fitting from previous version to latest version
    2008-11
    3
    Default Standard fitting from previous version to latest version
    I have upgareded Autodeks Building System 2006 to AutoCAD MEP 2009. In order to keep all the system fittings same as previous, can we take all the standard fitting from previous version to latest version i.e. from ABS 2006 to AutoCAD MEP 2009.
    I could stop if I wanted to ameador's Avatar
    2006-02
    424
    Default Re: Standard fitting from previous version to latest version
    I *think* you can....however, the 09 content has more info stuffed into them that help w/ the gbxml files and property set def's that work with new tags.
    I would test it with a couple before doing a mass change over.
    You may be losing new/improved info by dragging the past with you.
    CAD user since '95, CAD Mgr since '07, BIM Lead, Mech Eng
    R10, R14, 2000i, 2002, 2004, ABS 2007, AMEP 2009, 2011, 2012, 2013, 2014, 2015
    RMEP 2011, 2012, 2013, 2014
    REVIT 2015, 2016
    Author of: http://ab-nerd-disc.blogspot.com/
  1. 2008: Latest Version(s) Suggestions
    By rainparader in forum Inventor - General
    Last Post: 2014-01-13, 08:34 PM
  2. What is the latest version?
    By steve.perkio in forum NavisWorks - General
    Last Post: 2008-11-07, 09:11 PM
  3. New version of Previous.lsp
    By madcadder in forum AutoLISP
    Last Post: 2007-11-02, 11:50 PM
  4. DWF Composer what is the latest version
    By BCrouse in forum Design Review - General
    Last Post: 2005-07-07, 07:59 PM
  5. latest version Link
    By Jit in forum Revit Architecture - General
    Last Post: 2004-04-13, 08:55 PM
