Thread: wrong alingment file
    2008-02
    12
    Question wrong alingment file
    I'm using LDD 2004.
    Started the ddrawing up this morning and was going to work on a road went to set the alingment and noticed that the alingments shown were being referanced from a privious ldd folder (different name but same project).
    I tried to reassociate the file and that didn't work.
    I have a good Idea how this happened.
    Question 2
    How do you tell your supervisor that he needs to open ldd projects properly (told him many times but has a understanding problem) and that he should take a ldd course
    Super Moderator rkmcswain's Avatar
    Earth
    9,746
    Default Re: wrong alingment file
    An alignment belongs to a project. Sounds like your drawing got associated to a different project.
    R.K. McSwain | CAD Panacea |
    2008-02
    12
    I spent a good 2 hours creating a new project and making sure it all worked. The alingment are referancing the right file. I found out that there has been 3 other people had been in the file and one person was in the new file and had opened up the other file and then went to look at the alingments in the old project and then switched drawings and went to look at the alingments in the new project. I figure this is what has caused the association to change.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,017
    This can happen when you open more that one instance of LDD at time.
    Only have one instance of LDD open a time. If you need to look at additional drawings open an instance of Land Enabled (LE) Map.
    Jeff Paulsen
    2008-09
    7
    Gud day
    i think the alignment is no problem, when transferring ur project to other PC u must copy the project folder from the Land Desktop folder and copy the other PC with Land Desktop folder...
    I always do that and it works...
  1. Import alingment data from the another drawing
    By mendezangel78 in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2010-10-04, 01:59 PM
  2. HELP - eattext saved file wrong
    By MK.104584 in forum AutoCAD General
    Last Post: 2008-02-06, 06:20 AM
  3. My file is showing the wrong text
    By cknight.138477 in forum Revit - Platform
    Last Post: 2007-12-05, 03:44 PM
  4. file recovery gone wrong...
    By emodderman in forum AutoCAD General
    Last Post: 2007-07-10, 02:44 AM
  5. Wrong xref file being loaded
    By gregb in forum ACA General
    Last Post: 2005-04-20, 11:02 PM
