Im curious if anyone else has come across this, and if they handled it with Sheet Set or said, no way, cant happen, forget it.
I came from a company that used sheet set religiously on every job due to having 40+ sheets that changed alot, so it made it easy to handle info on them with fields, etc.
I am now at a location that uses individual drawing files that also have to retain the same drawing name and stay consistent through various jobs located in different folders.
Is there a way to use sheet set to do this? Or do all the drawings have to be in layout tabs on one DWG to correctly utilize sheet set.
