Thread: showing door heads in reflected view?
    2006-03
    85
    Question showing door heads in reflected view?
    How do you get the door heads to show up in reflected? I know I've set this before but I can't see to find it now.
    2006-03
    85
    Default Re: showing door heads in reflected view?
    Ok...nevermind! I figured it out! Took a lot of playing around and checking boxes but it's showing up right now.
    2003-10
    San Francisco CA
    1,190
    Quote Originally Posted by sharla View Post
    Hi Sharla,
    Glad you found a solution. If you know what you did could you post the solution so that it may help somebody else down the road?
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
  1. Reflected Ceiling Plan not showing revit link elements
    By barbara.ivo557941 in forum Revit Architecture - General
    Last Post: 2011-10-13, 03:30 PM
  2. Reflected Ceiling Plan View
    By c.mcmahon in forum Project Navigator
    Last Post: 2009-03-05, 01:04 AM
  3. View range - door not showing in plan
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2009-01-06, 04:29 PM
  4. Door & Window Display In Reflected Ceiling Plans
    By j_d_b_007 in forum ACA General
    Last Post: 2005-11-09, 04:31 PM
  5. Help with Reflected Ceiling Plan and view settings?
    By rgecy in forum Revit Architecture - General
    Last Post: 2003-09-19, 05:56 PM
