Results 1 to 10 of 12
Thread: match annotation scale to viewport scale
    Default match annotation scale to viewport scale
    I need a lisp routine that will match the annotation scale to the viewport scale in 2008. I have multiple viewports on the shame sheet file with different scales for each viewport. I am not sure where to go on this site to find code? I am a new member. Thanks!
    in the upper right corner
    3,508
    Default Re: match annotation scale to viewport scale
    Quote Originally Posted by Mary_Ellen_Banning View Post
    Hi Mary_Ellen_Banning, welcome to AUGI !
    This sounds more like an "annotative scaling" thing available in 2008+ and not a lisp routine. And because I don't have 2008, I can't help you, but others can.
    Cograts on your first post
    2006-12
    Big "D"
    3,711
    Yep, it already exists. Take a look at my screen shot. Please excuse my crude arrow!
    Basically, if it's toggled on, then, when you change the scale of your viewport an anno scale is automatically created and set for annotative objects.
    You may also be interested in the system variable SELECTIONANNODISPLAY.
    When set to 0, it turns off the other anno scales when you select dims and text, so there's no "ghosting".
    Thanks Ted,
    I guess I should have mentioned that I am saving these files from 2005 to 2008 with a script file running through many directories. The anno scale is being set to 1'=1' unless I pop into each viewport and edit the annotation scale. I wanted a lisp routine that would find the scale of each viewport and match the annotaion scale to that viewport.
    2015-11
    Jo'burg SA
    4,512
    OK, I've had the same problem. So I've created this routine - should work in a SCR.
    After loading the file, run one of these commands:
    • MatchVPScale to select the Paper Space View Ports to match with the closest AnnoScale, compared to their Zoom Factor
    • MatchAllVPScale to do the same for all Paper Space View Ports on all tabs in current drawing.
    2003-11
    285
    your lisp works great except when i run it in a tool palette command it returns this: "Command: ; error: bad argument type: <Entity name: 7ffffbb9760>"
    Also, I think you can make it return to the original layout as well by using a (setvar "ctab" obj) up front... (i'm not good with code btw, I just have a similar lisp file)
    any help would be appreciated.
    5,719
    Quote Originally Posted by randyspear View Post
    Not sure what version you're using, but since 2009 (not sure if it's always been this way?), Viewports support a one-way relationship between Annotation Scale, and Standard Scale.
    More specifically, if you set a Viewport's Annotation Scale, the Standard Scale automagically matches the Annotation Scale value... Just be mindful that this relationship is one-way, and subsequent changes to Standard Scale will not be reflected in Annotation Scale.
    Cheers
    Separately, since Irne originally provided LISP to resolve this thread's issue (back in 2008 ), I'll move it to the AutoLISP forum.
    2003-11
    285
    thanks, i'm using 2014. trying to automate the clean up of exported revit dwgs.
    the vpscales update to standard scales but the cannoscale within each stays at 1:1 until I either manually pick the scale again for each vport or run this lisp.
    5,719
    Just so I am clear....
    You open a Revit exported model drawing in AutoCAD, select a Layout Viewport, and in Properties Palette, change the Annotation Scale to desired scale, correct?
    2003-11
    285
    Sorry, i've replied to this 3 times and it doesn't seem to post.
    to answer your question, no, i open a revit exported drawing (with layouts), I have a tool palette command that runs the check standards to replace the unwanted styles, then it adds annotative scales to the text and dims and then at the end it loads and runs the matchallvpscales on the viewports. however I get an error on the matchallvpscales when I run it in the macro but if i run it separately, it works.
    The error is this:
    Command: matchallvpscale
    Initializing...._MSPACE
    There are no active Model space viewports.
    Command: AutoCAD variable setting rejected: "CVPORT" 4
  1. Replies: 9
    Last Post: 2015-08-21, 06:33 PM
  2. Set Annotation Scale Equal to Viewport Scale
    By CADdancer in forum AutoLISP
    Last Post: 2009-10-09, 04:48 PM
  3. match annotation scale to viewport scale
    By ccowgill in forum AutoLISP
    Last Post: 2009-05-04, 10:54 PM
  4. Annotation Scale different than Viewport scale!!
    By smooth shoes in forum AutoCAD General
    Last Post: 2008-10-17, 08:44 PM
  5. Replies: 0
    Last Post: 2006-11-28, 10:37 PM
