Here is what I use. Feel free to change it however you want.
;;;Sets the Dims
(Defun C:SetDims ()
(command "cmdecho" "0")
(Command
"_-Style" "Arial" ;Name of text style that is created
"Arial.ttf" ;Specify full font name or font filename (TTF or SHX)
"0" ;Specify height of text
"1" ;Specify width factor
"0" ;Specify obliquing angle
"_N" ;Display text backwards?
"_N" ;Display text upside-down?
"DIMADEC" "0" ;Angle precision
"DIMALT" "off" ;Alternate units
"DIMALTD" "0" ;Alt precision
"DIMALTF" "2.54" ;Alt scale factor
"DIMALTRND" "0" ;Alt roundoff
"DIMALTTD" "2" ;Alt tol precision
"DIMALTTZ" "0" ;Alt tol zeroes
"DIMALTU" "2" ;Alt units
"DIMALTZ" "0" ;Alt zeroes
"DIMAPOST" "cm" ;Alt prefix and suffix
"DIMASZ" "15/256" ;Arrow size
"DIMATFIT" "3" ;Fit: arrow and text
"DIMAUNIT" "0" ;Angle format
"DIMAZIN" "0" ;Angle zero supression
"DIMBLK" "" ;Arrow (ClosedFilled)
"DIMBLK1" "" ;Arrow 1 (ClosedFilled)
"DIMBLK2" "" ;Arrow 2 (ClosedFilled)
"DIMCEN" "23/256" ;Center mark size
"DIMCLRD" "6" ;Dim line color
"DIMCLRE" "6" ;Ext line color
"DIMCLRT" "7" ;Text color
"DIMDEC" "0" ;Precision
"DIMDLE" "0" ;Dim line ext
"DIMDLI" "97/256" ;Dim line spacing
"DIMDSEP" "." ;Decimal separator
"DIMEXE" "15/256" ;Ext line extension
"DIMEXO" "1/16" ;Ext line offset
"DIMFRAC" "2" ;Fraction format
"DIMGAP" "1/32" ;Text offset
"DIMJUST" "0" ;Text pos hor
"DIMLDRBLK" "" ;Leader arrow (ClosedFilled)
"DIMLFAC" "1" ;Length scales a Metric dimension to Imperial (5/127=0.3937)
"DIMLUNIT" "4" ;Length units
"DIMLWD" "-2" ;Dim line LW
"DIMLWE" "-2" ;Ext line LW
"DIMPOST" "\\X" ;Text prefix and suffix
"DIMRND" "0" ;Roundoff
"DIMSAH" "Off" ;Separate arrows
"DIMSCALE" "110" ;Overall scale
"DIMSD1" "Off" ;No dim line 1
"DIMSD2" "Off" ;No dim line 2
"DIMSE1" "Off" ;No ext line 1
"DIMSE2" "Off" ;No ext line 2
"DIMSOXD" "Off" ;No dim lines outside
"DIMTAD" "0" ;Text pos vert
"DIMTIH" "On" ;Text inside align
"DIMTIX" "Off" ;Text inside
"DIMTMOVE" "1" ;Fit: text movement
"DIMTOFL" "Off" ;Dim line forced
"DIMTOH" "On" ;Text outside align
"DIMTXT" "5/64" ;Text height
"DIMLIM" "Off" ;Tol limits
"DIMTDEC" "0" ;Tol precision
"DIMTFAC" "1" ;Tol text scale factor
"DIMTM" "0" ;Tol dev lower
"DIMTOL" "Off" ;Tol deviation
"DIMTOLJ" "1" ;Tol pos vert
"DIMTP" "0" ;Tol dev upper
"DIMTXSTY" "Arial" ;Text style
"DIMTZIN" "0" ;Tol zero suppression
"DIMZIN" "1" ;Zero suppression
"_Dimstyle" "_Save" "Evergreen" ;Saves the dimstyle
"_Y" ;In case the dimstyle's already there it will be overwritten, or an error will appear
"Graphscr" ;Ensures that the routine ends in graphscreen mode
(command)
(Command
"_-Layer" "_T" "_0-Dim" "_M" "_0-Dim" "_C" "253" "" "")
(command "cmdecho" "1")
;;;Updates the Dimensions in the drawing.
(defun c:DimUpdate ()
(C:SetDims)
(command "dim" "update" "all" "")
(command)
(graphscr)
(princ)
;;;CREATES THE _0-Dim LAYER. Allows a STRAIGHT Dimension. Then sets the 0 layer as current.
(Defun C:sd ()
(C:SetDims)
(command "dimlinear" pause pause pause)
(command "-layer" "Set" "0" "")
;;;CREATES THE _0-Dim LAYER. Allows a STRAIGHT CONTINUED Dimension. Then sets the 0 layer as current.
(Defun C:dc ()
(C:SetDims)
(command "dimcontinue" pause pause pause)
;;;CREATES THE _0-Dim LAYER. Allows a ALIGNED Dimension. Then sets the 0 layer as current.
(Defun C:da ()
(C:SetDims)
(command "dimaligned" pause pause pause)
;;;CREATES THE _0-Dim LAYER. Allows a RADIUS Dimension. Then sets the 0 layer as current.
(Defun C:dr ()
(C:SetDims)
(command "dimradius" pause pause)
;;;CREATES THE _0-Dim LAYER. Allows a DIAMETER Dimension. Then sets the 0 layer as current.
(Defun C:dd ()
(C:SetDims)
(command "dimdiameter" pause pause)
