Thread: Help with this color change LISP routine
    2004-10
    Wheat Ridge, Colorado
    97
    Default Help with this color change LISP routine
    AutoLISP Gurus,
    I managed to write this routine to change the color of a given group of layers. The problem is that when I try to use it on drawings that don't contain all layers listed, it doesn't work. I attempted to write an IF function that would check for the layer first, if it exists, then execute the command, if not, do nothing or print "no such layer" and move on, but it isn't working.
    Any thougts are appreciated.
    2006-10
    8
    Default Re: Help with this color change LISP routine
    Try this
    (defun LYCLR (LAYER COLOR / OBJNAME LAYLST)
      (if (tblsearch "LAYER" LAYER)
        (progn
         (setq LAYLST (assoc 62 (tblsearch "LAYER" LAYER)))
          (setq OBJNAME (tblobjname "LAYER" LAYER))
          (entmod (subst (cons 62 COLOR) LAYLST (entget OBJNAME)))
        (print "no such layer")
      ) ;_ end of if
    ) ;_ end of defun
    2004-10
    97
    Hrothgar,
    Thanks so much, that worked!
    So if I understand what was happening, when using IF by itself it expects only one expression where I was giving it three, and by nesting the PROGN function inside, LISP interpretted all expressions as one?
    Thanks Again,
    2006-10
    8
    Yes that's right.
    Also, someone else can probably say for sure, but I think overall it would run faster if you stored layer names and colors in a dotted pair list ie. (("layer1 . 2) ("layer2" . 4)), and then processed the list in one routine instead of multiple calls to Lyclr. But I'm only talking fractions of a second most likely, so it may not be worth the trouble at this point.
    2004-10
    97
    Many thanks. I will try using dotted pairs as I develop the routine.
    Peace,
  1. Change color of changed text routine
    By jayhay35365091 in forum AutoLISP
    Last Post: 2014-08-04, 07:44 PM
  2. LISP for change yellow color into Color 8
    By rhodinj1427782 in forum AutoLISP
    Last Post: 2014-01-16, 05:26 AM
  3. Layer Color Change LISP Routine
    By guardianfiredesign774457 in forum AutoLISP
    Last Post: 2013-08-28, 05:08 AM
  4. Replies: 10
    Last Post: 2007-05-06, 08:18 AM
  5. Color Change Routine - Layers & Objects
    By JohnnyFortune in forum AutoLISP
    Last Post: 2006-12-07, 12:24 AM
