Thread: ADMS Server installation problem
    2006-12
    3
    Unhappy ADMS Server installation problem
    Hey all,
    I have been trying to install ADMS 2009 on a Widows Vista Business machine. After spending too much time resolving IIS errors, I finally got to start installing. Installation goes well until I get a "Error 29001. Vault Management error: The request failed with HTTP Status 405: method not allowed."
    Install removes all installed components from that point and I have to start over again. Has anyone else had this issue?
    Whit McCormack
    DELL Precision 6300
    4GB RAM
    Windows Vista Business SP1
    AutoCAD Civil 3D 2009
    2007-09
    2
    Default Re: ADMS Server installation problem
    i had a similar problem and removed ipv6 fixed it. more info here:
    http://technet.microsoft.com/en-us/l.../cc779349.aspx
    which linked from here:
    http://discussion.autodesk.com/forum...ageID=6107161&
    and
    http://discussion.autodesk.com/forum...sageID=5919751
    i know this is a little late but i hope that helps someone else.
    -Mark.
  1. Revit Server installation - script required for this install could not be run.
    By r.howarth in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-09-02, 02:16 PM
  2. Installation Problem
    By max.johnson in forum Revit Architecture - General
    Last Post: 2010-10-12, 06:12 PM
  3. Vault 2010 Server Installation error
    By davor in forum Vault - General
    Last Post: 2010-04-14, 01:43 PM
  4. SP1 Installation problem
    By thm291966 in forum AMEP General
    Last Post: 2008-08-19, 03:18 PM
  5. Installation von vault 4 (data management server)
    By bantes in forum Deutsch - Autodesk Vault / Autodesk Productstream
    Last Post: 2008-07-11, 10:24 AM
