Is it possible to import a Revit drawing file (dwg) and somehow convert the objects to AutoCAD solids?
I would like to be able to import some Revit steel and then draw other AutoCAD solids and then use the AutoCAD INTERFERE command, SLICE command, etc.
Right now the Revit objects look like AutoCAD solids, shade etc, the same as ACAD solids, but I cannot use the AutoCAD commands on them.
Sarah-Jane
