Thread: Auto Numbering Blocks
    2008-11
    16
    Default Auto Numbering Blocks
    I use the express tools auto number all the time, I just need one to number my blocks.
    I have searched and have found some info on this topic but nothing that had works for me.
    I have a block "LoadTag" which has an attribute "Load" in it. Right now I add my load tags and manual update each one ie.MF.27 Then when the designer comes back and add a extra load in a room I have to go and relabel them all again.
    I would love to be able to have my tags number themselves, via X,Y or selection order. I have looked a few examples but they don't seem to work, and I haven't worked with Autolisps enough to no what is wrong.
    Can someone please point to in the right direction. I'm using AC09
    Thanks in Advance
    Kurt
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Default Re: Auto Numbering Blocks
    Here is the pseudo code:
    User selects the new block
    User enter new number
    Get all matching blocks in current space
    Iterate through selection set
    If LOAD is >= new number +1 number
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Could I just ask: Are all the blocks in the drawing numbered consecutively, or are there various sets of numbers? E.g. MF.1 --> MF.27, and SF.1 --> SF23, etc.
    2008-11
    16
    There will be different groups.
    LF - Lower Floor
    MF- Main Floor
    UF- Upper Floor
    PF- Penthouse Floor
    EXT- Exterior
    After giving it more thought I would still have to manually select each block, so the label order would flow with the floor plans. In a perfect world it would work like the AutoNumber in Express Tools, just on my loadtag block.
    Using some code that a member posted in a different topic I have the numbers incrementing on placement, which is nice but doesn't help me when I need to re-number because of additions or deletes.
    2007-11
    68
    Post Re: Auto Numbering Blocks
    I'm also in the need for this type of lisp.
    Also one other thing can you make sure it works with dynamic blocks.
  1. 2013: Auto-numbering
    By fjtdogeno in forum Revit Architecture - General
    Last Post: 2012-08-22, 04:03 PM
  2. Auto Numbering
    By sandeep_koodal in forum AutoCAD Tips & Tricks
    Last Post: 2012-05-16, 03:25 PM
  3. Auto Numbering
    By windowsxp5 in forum AutoLISP
    Last Post: 2011-11-11, 10:59 AM
  4. Auto Numbering tools Lt
    By neilcheshire in forum AutoCAD LT - General
    Last Post: 2008-03-05, 12:49 PM
  5. Auto-Numbering lisp
    By ldgodsey in forum AutoLISP
    Last Post: 2007-11-19, 09:51 PM
