Thread: Short Cut (Right Click) Menu
    Active Member marble's Avatar
    2003-08
    Cincy
    53
    Default Short Cut (Right Click) Menu
    In the beginning everything was working fine, then BAM (no I was not cooking) my hard drive decided to crash. Well now I have a new HD and everything is working fine.....EXCEPT my right click will not work, nada, nill, zip. I check the setting on my machine to see if it was on, yep it is, and my settings are set like my co-workers. need help trying to figure this out. Without that right click my productivity/speed has dropped.
    No right click in a command, not in a command, and no Shift-right click Osnap (the one that really ticks me)
    150700
    3,439
    Default Re: Short Cut (Right Click) Menu
    I would first check your mouse setting in Windows to make sure they are the same as your co-workers. Is right click working in other apps (not that there are many that use it)
    2003-08
    Cincy
    53
    I checked my co-workers and we have the same settings for the mouse,
    13,656
    Hi
    Have a browse of the following threads -
    RIGHT CLICK GONE since I loaded WaterCAD
    Right-Click doesn't work
    Middle Button OSNAP?
    Have a good one, Mike
    2003-08
    Cincy
    53
    THANK YOU THANK YOU THANK YOU, Thanks for the links to the other problems there was some good help there. Ahhhhhhhhhhhhhhhhhhhhhhhhh my menu is back...............
    Thanks again!
  1. Add right click short cut for applying constraints
    Last Post: 2010-09-21, 02:28 PM
  2. Right click short-cut menu missing default commands and options
    By Bill.Jensen in forum AutoCAD CUI Menus
    Last Post: 2006-06-29, 02:48 PM
  3. Right Click Short Cut Menu disappeared.
    By irene.beech in forum AutoCAD General
    Last Post: 2006-06-22, 08:30 AM
  4. Right click short-cut menu does not display
    By Rico in forum AutoCAD General
    Last Post: 2005-07-12, 01:49 PM
  5. right click short cut menu woes
    By JASONM30395 in forum AutoCAD Customization
    Last Post: 2004-06-25, 11:52 AM
