Results 1 to 10 of 10
Thread: Save/Open crashes CAD
    2004-07
    Detroit Michigan
    2,508
    Default Save/Open crashes CAD
    AutoCad is closing when I open and/or save a file.
    Any ideas what may be causing the error?
    Is there a hotfix?
    2008-06
    Richmond, VA
    141
    Default Re: Save/Open crashes CAD
    One particular file, or any file?
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    Knowledge Base is our friend.
    http://usa.autodesk.com/adsk/servlet...linkID=9240617
    HTH
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by Richard.Kent View Post
    and unloadind MdiTab will close the drawings tabs? Don't want to do that.
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by amsterdamn View Post
    Yes, any file.
    2004-08
    Hartford, Michigan
    3,197
    I periodically have experienced this, and I never downloaded dwgtabs for 09.
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    Active Member davidmatyas's Avatar
    2005-01
    72
    Robert:
    I think your asking alot!!! Opening and saving a drawing??? Can't you just be content with your capability to draw lines and plines, circles and other geometeric shapes??
    Can you plot? Maybe plotting can be a viable solution to your saving problem. Draw...Plot....Erase...........Draw....Plot.....Erase...........Draw....Plot.....Erase
    David M. Matyas
    Matyas_COMP_Services
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by davidmatyas View Post
    Robert:
    So funny, weisenheimer
    I do have one program that does exactly that. It generates a view that cannot be saved.
    I think it was meant for explorating options instead of producing actual specs.
    I have to take multiple screen captures.
    2005-01
    72
    How are you accessing the save and/or open commands? If you are using the FILE pulldown then check this out.
    else maybe Mditab.arx is corrupt. Do you get the same results from typing the commands at the command prompt?? Toolbars?
    David M. Matyas
    2001-01
    622
    Quote Originally Posted by Robert.Hall View Post
    It won't close the drawing tabs, it will just remove that so-so add on autodesk provided. If you use it then getting rid of it will let you save and open. Seems like an easy choice.
  1. 2013: 2013 Autocad crashes while trying to save
    By kimlance in forum AutoCAD General
    Last Post: 2013-09-23, 10:09 PM
  2. Central file crashes after two consecutive people save?
    By andymeyer50 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-11-21, 02:05 AM
  3. Revit Crashes whenever I do a Save As
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2009-11-09, 12:59 PM
  4. Save Timeline Position on Save/Open
    By stusic in forum 3ds Max - Wish List
    Last Post: 2009-08-04, 03:44 AM
  5. AutoCAD 2007 crashes while trying to save a profile
    By ch00su in forum AutoCAD General
    Last Post: 2006-09-20, 03:48 AM
