Thread: Filling in a title block from an excel sheet?
    2008-11
    12
    Cool Filling in a title block from an excel sheet?
    Guys,
    I know this can be done but haven't a clue on how to do so. I have tried looking for routines a like to try manipulate, maybe I am just not searching for the right things?
    Does anyone have a routine that may do this or similar?
    Does any one have a routine they would donate so to manipulate to do the task?
    Any assistance is much appreciated, thanks.
    2008-11
    16
    Default Re: Filling in a title block from an excel sheet?
    I don't know if this will help you or not. I use it to import/export my title block info to the custom section under DWGPROPS. Then link the custom props to my block using fields. It will import/export Tab-Delimited Text files which you can use excel to generate.
    **I didn't write this I just ran across it in my search for an Block Auto Numbering Lisp**
    2004-08
    Iron Station, NC
    3,198
    That code looks very familiar, here is the original post as well as the txt file to be modified using excel, and some brief instructions for use. I would post the most recent update, but it has too much customization tied in for our office to be able to make it useable elsewhere. If you want to see the original discussion and the code in its oldest, non-company oriented version, you can also check out this thread. It may help you understand where the code came from and how some of the features work.
  1. Extract Title Block Attribute Data to Excel
    By bzrqmy in forum AutoCAD Customization
    Last Post: 2017-04-26, 06:26 AM
  2. 2013: Batch extraction of title block attributes to excel
    By robechandler167079 in forum AutoCAD General
    Last Post: 2015-04-28, 07:29 PM
  3. Importing Title Block Info from Excel
    By stusic in forum VBA/COM Interop
    Last Post: 2012-04-04, 04:45 PM
  4. Filling in a title block from dialog box input?
    By aaron.bentley in forum AutoLISP
    Last Post: 2008-12-02, 01:00 PM
  5. Is there a way to export a sheet title to an Excel file?
    By RCA4697 in forum AutoCAD Customization
    Last Post: 2006-08-04, 09:47 PM
