Thread: Dimensional CALS
    2008-04
    215
    Default Dimensional CALS
    Can anyone educate me on what a:
    Dimensional CALS Type 1 (CCITT G4 2D Compression).pc3
    is?
    All I know about this printer is that it prints ACAD files in a compressed .tff file that the government uses. We are required to supply the Government these CAL files. But it is hit or miss with Dim CAL printer, most of the time the print jobs fale with a T.6 Error.
    We have to use a Microstation to open the files and print thru IPLOT Organizer to get our CALS out.
    Does anyone else use Dimensional CALS Printer and have the same issue with the file failing to print with a T.6 Error?
    Is there a newer version of Dim CALS printer out there. I am searching the web for something but coming up dry.
    Thanks for you time and help
    0,0,0 The Origin
    8,570
    Default Re: Dimensional CALS
    This is probably no help but I know that CALS is a compressed image file that is used by some large scanners for output and, I think, by fax machines.
  1. 2014: Dimensional Constraints
    By Frank Dux in forum AutoCAD General
    Last Post: 2013-06-11, 11:49 AM
  2. dimensional bit rot
    By btrusty in forum Revit Architecture - General
    Last Post: 2010-01-29, 02:53 AM
  3. Saídas em Formatos Raster do AutoCAD (Windows BMP, CALS
    By Brogueira-CADptbr in forum AutoCAD General
    Last Post: 2007-07-14, 03:15 PM
  4. UK Energy Cals, gbXML & Revit
    By Damo in forum Revit Architecture - General
    Last Post: 2006-07-26, 09:39 PM
