I imported via XML a pipe network from Hydraflow and want to label the pipes and structures. The pipe sizes are correct but the descriptions in the network vista are not. As best I can tell this is what is used to label the structures. What controls the description setting when importing information from XML? Do I have to manually change the description once I import the XML file or is there a setting somewhere that will allow the description to assume the data from the XML file?
