Results 1 to 8 of 8
Thread: content builder multiview part
    2008-05
    66
    Default content builder multiview part
    hi
    anyone can help me, please.
    i got question about create a multi-view part,
    Can we create our own custom type, custom layer key and custom subtype? (see the attachment picture)
    because i need to create a pipe connector (flange adapter) which is at connector type.
    but i cant find any connector type in the list.
    and i cant choose other type, because when i create a pipe fitting schedule, it will total together (connector )with the type i had choose.
    sorry poor English, hope u can understand
    thanks
    2007-10
    Tucson, Arizona
    613
    Default Re: content builder multiview part
    Sam,
    You can have a custom Layer Key, but you cannot create custom Type or Subtypes. This was a bummer for me too.
    See this thread: http://forums.augi.com/showthread.php?t=70751
    -Buzz
    2008-05
    66
    thanks for help
    but let say i got one complicated pipe fitting (flange adapter = connector) to create, so i cant put in parametric part because to hard to model then i have to put in multiview part but i cant find connector in the list. anyone got other suggestion?
    the problem is
    now i put in valve category but when i create take off list the connector with be total together with valve quantity.
    any suggestion to separate them. please help.
    sam
    2008-05
    66
    anyone can help please reply?
    2007-10
    Tucson, Arizona
    613
    Sam, can you upload some screenshots showing what you are talking about - I am a little unclear as to what you are looking to do.
    -Buzz
    2008-05
    66
    hi buzz,
    i had done three screen shot, hope this time u will get what i meant.
    sorry for poor explaination.
    thanks for help
    sam
    Why do you need such complexity in the part? You could easily model this parametrically without the bolts and other details. A complex model only leads to potential performance issues and that level of detail typically isn't required for Construction Documents.
    You could create this as a Pipe Fitting with Part Type set to Connector, similar to what we do with our Pipe Adapters. You could then enable the AutoLayout flag and use it in your Routing Preferences if desired.
    If you feel an MvPart is the better way to go, I would suggest using the Custom Part Type. You could then add a custom parameter in Content Builder or use Property Set Data to schedule it as you need.
    At this time, it is not possible to alter the list of MvPart Part Types. The list is hard-coded in the application. We can add more to it for a later release if people let us know which additional ones they would like added. We're also exploring the possibility of making the list extensible in the future.
    Hope that helps,
    Toby Smith, PE, LEED AP
    AutoCAD MEP Product Manager
    2008-05
    66
    hi thanks for your suggestion,
    but this connector must with the bolt together. if without bolt, i know that is easy to create in the parametric part. unfortunately i really need the bolt.
    yeah, i think new release version must able to let people to add a custom part type. because a part from that there is a lot of different connector or piping fitting are difficult to create in parametric part.
    if custom part type is really hard to make it, then i suggest the part type can have a new type example like (connector, piping fitting or pipe)
    thanks
  1. CV218-4: Get the Part: AutoCAD Civil 3D Part Builder
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:52 AM
  2. 2014: mvpart content builder parametric part
    By pdoan in forum AMEP General
    Last Post: 2013-12-17, 01:32 PM
  3. Error using Content Builder
    By nubrun.188780 in forum AMEP General
    Last Post: 2008-08-13, 02:53 PM
  4. content builder discussion
    By sam_ctlim in forum Parts Builder
    Last Post: 2008-05-09, 06:27 PM
  5. content builder help! help!
    By windpower in forum AMEP General
    Last Post: 2008-01-26, 01:24 AM
