Results 1 to 10 of 10
Thread: The same font looking deferent
    2007-04
    60
    Default The same font looking deferent
    Hi all,
    We have a project and the arch. Come out side the company and the drawing have a font STENCIL.shx it looking good for each machine except one
    And I don’t know the reason may be variable or the graphic card …etc
    Note this problem in AutoCAD 2008 and 2009
    The attached may be explain more than me
    Have any one help me in this problem
    2016-01
    Sweden
    12
    Default Re: The same font looking deferent
    The required font is maybe missing on that machine, so the font specified in the altfont environment variable is used instead.
    2007-04
    60
    I check this case and I put new file for this font but it doesn’t work
    9,805
    Quote Originally Posted by e.mounir View Post
    Paste this to the command line:
    (findfile "stencil.shx")
    on both machines. What does each return?
    2007-04
    60
    It is not working “Unknown command “ sorry can you clarified please
    2007-04
    60
    Wait it is working for good one gives me “nil” but the bad one gives me path C:\\DARMENU\\D\\ STENCIL.shx
    0,0,0 The Origin
    8,570
    Are you sure? The BAD one should return "nil".
    If that's so, and you have copied stencil.shx to the (acad path)\fonts folder on the bad machine, close and restart acad on that machine. Acad only checks the available fonts when it starts.
    2007-04
    60
    I make both of them is nil and make restart the bad one and it is still bad
    2016-01
    Sweden
    12
    So in one of your installations you have the font and in the other one not.. But you call the one with the font missing the good one, it is not. If you don't want to use that font you should change it in the dwg file.
    2016-01
    Sweden
    12
    Make sure the fontalt environment variable is set the same on both machines if you want it to look the same if a font is missing.
  1. Replies: 1
    Last Post: 2009-05-07, 11:18 AM
  2. Text font shows wrong font - revit to blame?
    By jblack.150078 in forum AutoCAD General
    Last Post: 2007-10-10, 08:11 PM
  3. Update font used in multiple dimension styles to one common font file
    By tomasz.stachowiak in forum AutoCAD General
    Last Post: 2007-03-22, 08:54 AM
  4. Font will change to another font when opening a drawing
    By mellyskelly in forum AutoCAD General
    Last Post: 2006-10-21, 05:01 AM
  5. Converting SHX Font to True Type Font
    By dortega4269 in forum Revit Structure - General
    Last Post: 2006-09-01, 05:19 PM
