Results 1 to 10 of 10
Thread: Remove Data Extractions
    All AUGI, all the time gfreddog's Avatar
    2003-07
    Pequannock NJ US of A
    641
    Default Remove Data Extractions
    Okay here's my latest "weird one"
    I have a drawing that I did a Data Extraction to. I created a table in the drawing and a linked XLS file.
    We no longer need the extraction. So, I delete the table. But the Data Extraction.dxe still shows up in the External Reference Manager.
    How can I delete these "links" if they don't show up anywhere except in the External Reference Manager?
    Any ideas?
    George V. Fournier Jr., CTS
    Sr. Sales Engineer - Autodesk Product Design Suite Premium 2014
    2006 AUGI DAWG (7th) - NJ AUGI Camp
    Volunteer Firefighter since 1985 & Bagpiper Wanna-be
    With the freedom of expression comes great responsibility
    2008-03
    383
    Default Re: Remove Data Extractions
    There are no explanations on Help on how to remove it. And it says on Xref Manager that "Data Link selected: Cannot reload, detach or bind". Also, if you go to DATALINK manager there are option there to delete but if you click on that it prompts a warning that it is in use. I am not sure but AFAIK there are no available options aside from that for removing or detaching this kind of reference.
    2003-07
    641
    Quote Originally Posted by archie.manza View Post
    Yeah that's my problem. I tried all of those avenues to no avail.
    Normally I would just say screw it BUT anytime I run Publish or E-Transmit it looks for the files that are not there and throws an error that I can usually click through but it's a pain.
    If my client opens the E-Transmit files and sees the errors they call looking for the missing files
    2008-12
    Try typing the command DATALINK and then right click on the table/legend etc. that you want to remove. Select delete. This should remove it from your file.
    Member jmcbride.161140's Avatar
    2008-02
    North Seattle
    42
    I had this same problem and after searching forever on how to fix it I found this lisp that was a godsend! The writer is Irne Barnard so he gets all the credit!
    Miah
    2003-07
    641
    Quote Originally Posted by jmcbride.161140 View Post
    Newbie question... What is the .DCL file for?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by gfreddog View Post
    A dcl file contains the definitions of the user interface elements so that a lisp routine can have text boxes, radio buttons and all the other pretty things we've become used to instead of being just a command line operation.
    John B
    2015-11
    Jo'burg SA
    4,512
    Just a warning ... my code can stuf things around if used improperly. I've tried disallowing things that shouldn't be done, but I might have missed something ... you can of course Undo, but if you've saved & closed ... well ...
    See the orininal post for usage of this routine: http://forums.augi.com/showthread.php?t=78139
    Quote Originally Posted by LArchy View Post
    This solution worked for me. Thanks, LArchy!
    2017-02
    Denmark, Copenhagen
    3
    Great method thanks
  1. remove data link from drawing??
    By guyver1 in forum AutoCAD General
    Last Post: 2021-04-05, 02:51 PM
  2. 2013: Import shapes and attached data (shapefile, object data etc) to Revit
    By cooperch663326 in forum Revit Architecture - General
    Last Post: 2014-06-02, 10:53 AM
  3. 2009 Add/Remove rows from SDF non-spatial class Data Table
    By fo1966403314 in forum AutoCAD Map 3D - General
    Last Post: 2013-07-23, 11:49 AM
  4. Remove data from parameter in schedule
    By drewj in forum Revit MEP - General
    Last Post: 2010-11-10, 05:45 PM
  5. Remove Point Data but leave Block Symbols Intact
    By fgolaub in forum AutoCAD Civil 3D - General
    Last Post: 2008-05-19, 10:46 PM
