Thread: Design review area and measurment issue
    2006-11
    72
    Default Design review area and measurment issue
    Hi all,
    One of our owners here has been double checking takeoffs of houses as bills come in to basically make sure we aren't wasting any money or over paying subs. He was checking basement concrete footage and got a number over 500 sq. ft. less than was billed for & was upset thinking he'd been ripped off. I checked the dwf and even republished it getting the same inaccuracies but only on that one sheet. The strange thing is when I measure some lengths from top to bottom they come out totally wrong but if i redo it from bottom to top it is correct. if I move one of the incorrect dimensions around on the sheet it switches back and forth from the wrong length to the correct length. Also if I take some test areas of some rectangles, they are correct. Does anyone have any idea what's going on here? Hopefully the pics will make things easier to understand. Thanks in adavance!
    Cole
    2000-01
    Seattle WA USA
    5,859
    Default Re: Design review area and measurment issue
    Can you post the DWF and DWG file? What versions of each software are you using?
    R. Robert Bell
    Design Technology Manager
    Stantec
    2006-11
    72
    Hi Robert,
    Thanks for replying. I'm using 2009 versions of both. I think the original dwf was done in a previous version but I got the same results when I recreated it. Would it be possible to email you the files?
    2000-01
    Seattle WA USA
    5,859
    Yes, you may. Use AUGI's interface to email me.
    R. Robert Bell
    Stantec
  1. Revit and Design Review scale issue
    By graphite in forum Design Review - General
    Last Post: 2011-12-19, 06:31 AM
  2. Design Review Status Issue - Revit 2008
    By clintr in forum Revit Architecture - General
    Last Post: 2007-11-10, 01:30 AM
  3. Revit / Design review measurment problem
    By peakprecisiondesign in forum Revit Architecture - General
    Last Post: 2007-07-03, 04:24 PM
  4. Replies: 1
    Last Post: 2007-02-11, 02:22 PM
