Thread: Reveal Question
    2008-12
    11
    Default Reveal Question
    Newbie to Revit (got that out of the way)
    I am trying to use a reveal to "notch" out areas of stud in my walls in section. I noticed that I can use grips to lengthen the reveal but is there a way to make the height and width adjustable on the fly. I am trying to avoid having to create different sized profiles. I am unsure how to make a profile parametric and have the parameters show up in the properties box of the reveal when I want to adjust the height and width.
    Thanks for any help
    Pittsburgh, PA USA
    1,906
    Default Re: Reveal Question
    Quote Originally Posted by sethridge View Post
    Newbie to Revit (got that out of the way) I am trying to avoid having to create different sized profiles. I am unsure how to make a profile parametric and have the parameters show up in the properties box of the reveal when I want to adjust the height and width.
    You cannot make a profile "adjustable" in size on the fly. You can make a profile that hase different sizes within one profile family. A reveal, (or sweep) can only have one profile size in it at a time. You have to make a different reveal "family" or type for each size profile.
    2008-12
    11
    Is there a better way to do this than reveals?
    2005-12
    Orlando, Florida
    234
    The solution is create a profile family with different sizes, Is not quite hard. Use refence planes in your family an attach the profile lines to these planes, then dimension these reference planes and add parameters that will change according the type of profile you will use.
    Good luck
  1. Reveal Hidden tool should reveal section lines that "hide at scales coarser than"
    Last Post: 2010-03-12, 05:53 AM
  2. void reveal family instead of wall reveal
    By t1.shep in forum Revit Architecture - Families
    Last Post: 2010-01-08, 10:15 PM
  3. Vertical wall reveal - Reveal profile
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2008-12-18, 09:52 PM
  4. Reveal and Wall Question (moved from Protecting Families Thread)
    By fjtdogeno in forum Revit Architecture - General
    Last Post: 2008-01-26, 06:42 PM
  5. Wall reveal - question
    By mhardybrown1911 in forum Revit Architecture - General
    Last Post: 2004-04-08, 03:23 PM
