Thread: LISP CHALLENGE - symbols created within routine
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Default LISP CHALLENGE - symbols created within routine
    I cannot figure this one out so I thought I would post a challenge.
    I have several lists created in a routine:
    (setq layers-PLAN (list .....))
    (setq layers-RCPL (list .....))
    (setq layers-ELEV (list ...))
    (setq layers-SECT (list ...))
    I am trying to return these lists when a user clicks a radio button with key values as follows: (setq user_input $key)
    PLAN
    RCPL
    ELEV
    SECT
    I know how to use the set command to SET an expression to a symbol.
    (set (read (strcat "layers-" $key)) (list ....))
    What I do not know is how to return a value by building a symbol from user input.
    (setq user_input_layers (read (strcat "layers-" $key))) returns LAYERS-PLAN and not the predefined list.
    Any help would be appreciated. If you help out, I'll put in a good word to Santa.
    Brad Novak
    Director of Information Technology
    Gp GOETTSCH PARTNERS
    Chicago, IL
    2007-08
    201
    Default Re: LISP CHALLENGE - symbols created within routine
    Hi,
    Not sure having understood the request cause of my poor English, but may be with eval function ?
    (setq user_input_layers (eval (read (strcat "layers-" $key))))
    2002-12
    77
    how are the layers themselves named? it may be easier to just make one big list and (vl-sort) them to get what you need?
    2003-11
    Chicago
    1,233
    Quote Originally Posted by 'gile' View Post
    Hi,
    WOO HOO!!
    I think you did it! I just had the eval function in the wrong place during my tests!!!
    Thanks again. (Santa will be notified)
    Brad Novak
    Chicago, IL
  1. Anyone up for a LISP challenge?
    By Rroger_D in forum AutoLISP
    Last Post: 2015-08-06, 02:37 AM
  2. Select the last N entities created in a lisp routine.
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2015-06-23, 04:36 PM
  3. Help with a lisp routine to add a 12" line to this routine
    By Orbytal.edge341183 in forum AutoLISP
    Last Post: 2012-11-14, 10:33 PM
  4. LISP CHALLENGE: Explode Polyline and Keep Width
    By bowlingbrad in forum AutoCAD Customization
    Last Post: 2009-08-29, 05:52 PM
  5. LISP Challenge - draw a specialized leader
    By fletch97 in forum AutoLISP
    Last Post: 2006-02-28, 08:35 PM
