Thread: rotate/Slope a wall in vertical plane
    2008-12
    12
    Default rotate/Slope a wall in vertical plane
    I'm unable or unaware how to rotate a wall vertically (or slope)...should I be using a ceiling or slab?
    2006-01
    4,516
    Default Re: rotate/Slope a wall in vertical plane
    You have to make a mass that has one face sloping, and then use the massing > Wall By face, to place a wall on the slanted face of the mass.
    You can either make a mass/Generic Model Family, or (if its a one off) you can make the mass under Modeling > Create > Mass.
    2008-12
    12
    Thanx.....quick and helpful - solved my problem in no time flat!
  1. Slope in Vertical Pipe?
    By kmcglothlin in forum Revit MEP - General
    Last Post: 2017-12-06, 05:51 PM
  2. slope reference plane
    By aedwards24 in forum Revit - Platform
    Last Post: 2010-06-09, 11:01 AM
  3. Roof slope by ref plane
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2006-08-29, 08:02 PM
  4. Curtain wall with 45deg slope up to vertical curtain wall
    By jsaid in forum Revit Architecture - General
    Last Post: 2006-01-10, 04:15 PM
  5. Mask difference on vertical plane vs. horizontal plane.
    By SkiSouth in forum Revit - Rendering
    Last Post: 2004-04-24, 01:08 PM
