Results 1 to 7 of 7
Thread: Hollow polyline and solids in modelspace
    I could stop if I wanted to Mamma Jamma's Avatar
    Massachusetts
    343
    Default Hollow polyline and solids in modelspace
    2nd problem of the day...having fun now
    User's drawing (ACAD 2007) has polylines and solids in modelspace that are "hollow".
    Fillmode=1
    Shademode=2d wireframe
    Plines and solids are fine in the Layout (thank God for small mercies - it plots ok)
    Plines and solids are fine if copied and pasted into another drawing.
    Any ideas?
    0,0,0 The Origin
    8,570
    Default Re: Hollow polyline and solids in modelspace
    likely - set PLAN = Current UCS
    possible - set TARGET = 0,0,0
    2015-11
    Jo'burg SA
    4,512
    If the PLINES are drawn on a different UCS you need to view them head-on. UCS OBject select polyline, then PLAN Current UCS. But that may stuff your drawing around a bit
    0,0,0 The Origin
    8,570
    but would they plot okay?
    more likely that the mspace view is not a plan but the vport view is a plan.
    2015-11
    Jo'burg SA
    4,512
    You're probably correct, I'm just thinking of any and all possibilities.
    2004-11
    8
    I had the opposite problem. Unlock the viewport, type PLAN, select WORLD, reset viewport scale, reposition items in viewport, LOCK viewport. The key to both problems seems to be the PLAN.
    Wayne R. Cameron
    2015-11
    Jo'burg SA
    4,512
    Yes, that's exactly what jaberwok was referring to . PLAN changes the view to be dead-on-straight to the selected UCS (usually World). 2dSolids / PLines with width usually display as outlines if the view is not dead-straight onto them.
    Now if your viewport is not "Plan" on WCS, most probably someone has also changed the UCS. In which case, it might even be that the polylines were drawn on a different UCS than world. In which case PLAN World could actually cause the problem.
    If you're forced to display polylines at an "angle", you're stuck with outlines only. Otherwise you could use a realistic / conceptual visual style ... ... but that's probably not what you'd want for technical drawings
  1. Polyline width shown as hollow outline
    By mermercad in forum AutoCAD General
    Last Post: 2017-01-19, 08:15 PM
  2. Replies: 13
    Last Post: 2016-09-19, 05:43 PM
  3. Hollow polyline
    By dalexmed941333 in forum AutoCAD General
    Last Post: 2011-12-13, 05:14 AM
  4. Hollow Polyline problem
    By orginaz2 in forum AutoCAD General
    Last Post: 2011-02-17, 03:47 PM
  5. polyline shows hollow
    By Maverick91 in forum AutoCAD General
    Last Post: 2009-05-27, 01:51 PM
