Results 1 to 6 of 6
Thread: snap problem in some x-ref file
    2008-12
    4
    Question snap problem in some x-ref file
    when i open drawing which loaded with x-ref file & i tried to placed a new line,circle or anything or xref 's snap point but i'cant get a xref-sanp point .
    so please help !!!!!!!!!!!!!!!!!!!!!!!!!
    2006-12
    Big "D"
    3,711
    Default Re: snap problem in some x-ref file
    Welcome to AUGI and congrats on your first post
    Make sure the 0 layer is not frozen.
    2008-12
    4
    i tried a lot but it did not work if you or anybody have any idea about this.
    thanks
    I could stop if I wanted to sschwartz85916's Avatar
    2005-04
    Oakland County, Michigan
    424
    Are there AEC objects in the drawing? Typically when we get an ADT drawing with a ceiling drawn with within a space, and the drawing had not been exported to a different version properly, I have to explode the ceiling to be able to lay the lights in and snap to the grid. (2D drawings).
    2008-05
    161
    Entities with Z coordinates in the x-ref could cause issues too.
    For instance if Intersection doesn't work but Apparent Intersection does. Then it usually means you have differering Z coordinates.
    2008-03
    383
    Quote Originally Posted by icbinr View Post
    This is true it happens to me before, and the only way we can fix it is by placing all the Z into 0,0.
  1. view range and snap problem
    By Cheuk Ling in forum Revit Structure - General
    Last Post: 2006-06-22, 05:25 AM
  2. Problem with SNAP
    By dziemer in forum ACA General
    Last Post: 2006-06-18, 11:32 AM
  3. Interior Elevation snap problem
    By schultzk in forum Revit Architecture - General
    Last Post: 2006-05-15, 09:21 PM
  4. Snap perp problem with rotate
    By gordolake in forum Revit Architecture - General
    Last Post: 2006-03-01, 10:44 PM
  5. Nearest Snap Problem
    By tblack.62739 in forum AutoCAD CUI Menus
    Last Post: 2005-09-01, 05:42 AM
