Results 1 to 6 of 6
Thread: Open a specif exel file from AutoCAD
    2008-01
    Madison, WI
    81
    Question Open a specif exel file from AutoCAD
    I have been trying to figure out how to open a specific sreadsheet from AutoCAD. I can open Exel by using (startapp "C:/.../exel.exe") without any problem, but how do I tell it to open a specific file?
    Any ideas?
    thank you for your help!
    Super Moderator rkmcswain's Avatar
    Earth
    9,746
    Default Re: Open a specif exel file from AutoCAD
    If this is just for you, then something like this should work, after you change the path to Excel if needed.
    (startapp "C:\\Program Files\\Microsoft Office\\Office12\\EXCEL.EXE" "C:\\Book1.xlsx")
    But if you are using this on different machines, then the path could be different. A better solution is to let Windows open the associated program.
    There is an example here of opening a PDF, just change the name of the file to your Excel file and it should work no matter what version of Excel you have or where it's located on the system.
    R.K. McSwain | CAD Panacea |
    2008-01
    Madison, WI
    81
    Talking Re: Open a specif exel file from AutoCAD
    works perfectly, thank you!
    100 Club sandeep_koodal's Avatar
    2007-10
    God's Own Country
    183
    Thumbs up Re: Open a specif exel file from AutoCAD
    Click "Open" icon and type *.* on the file name tab and browse, then right click the file name and choose from options
    2004-07
    Detroit Michigan
    2,508
    Would the windows quick launch toolbar work for you?
    I have a half dozen shortcuts to spreadsheets on the windows taskbar.
    It can be set to autohide so it moves out of the way when drawing.
    2015-11
    Jo'burg SA
    4,512
    What about placing a hyperlink (Ctrl+K) on one of the objects in the DWG pointing to the file. Thereafter hold down Ctrl and pick the object.
  1. Exel opens in Wrong Version of autocad
    By leinaD in forum AutoCAD General
    Last Post: 2010-06-14, 02:13 PM
  2. Replies: 10
    Last Post: 2007-02-07, 07:43 PM
  3. Replies: 15
    Last Post: 2006-11-23, 03:47 AM
  4. Replies: 2
    Last Post: 2006-03-24, 10:14 AM
  5. Lost File/Open File/Save Dialog Box on Autocad 2000i
    By thegoffs.89856 in forum AutoCAD General
    Last Post: 2005-06-30, 09:05 PM
