Thread: Plans Blacked out when printing
    2009-01
    3
    Question Plans Blacked out when printing
    Hi,
    I have an issue when printing. The viewport is okay on the screen everything can be seen, but when I go to print the veiwport is completely blacked out. I have tried to import the file, but it is still blacked out when I print. Has anyone go any suggestions?????
    TF
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Default Re: Plans Blacked out when printing
    does it print okay on other pages?
    can you print from the model?
    can you print to pdf/dwf?
    do you get a successful print preview?
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    2009-01
    3
    Have tried all of this, and it still blacks out the plan. It does show dimensions but no lines?
    2004-07
    Perth Australia
    736
    Have you audited the file?
    If you could get a soft copy I'd have said printer driver, but it's not that likely that your printer, pdf and dwf drivers are all quirky at the same time.
    Can you print from other projects? (If yes, maybe post your file/partial file so we can see if anyone else can print it)
    It almost sounds like you have an objct blocking out your plan, but if you can't get model info on any views then I'm at a loss.
    Kathy Taylor
    TaylorCAD
    2009-01
    3
    Smile Re: Plans Blacked out when printing
    Hi,
    Have tried all that. But you are a live saver. I have just doen a partial save of viewports and when I drop it into another file it is printing.
    Thanks for helping trough thisa issue with your suggestions.
    Tammy
  1. 2015: Pipes In Type Selector Blacked Out
    By bt1101011 in forum Revit MEP - Families
    Last Post: 2015-02-25, 11:22 AM
  2. A "TIFF" Logo is plotting all Blacked out
    By dallas.leinweber in forum AutoCAD Plotting
    Last Post: 2010-10-19, 02:23 PM
  3. Detail lines Floor Plans and Ceiling Plans
    By techsupport.161645 in forum Revit Architecture - General
    Last Post: 2010-02-05, 06:57 PM
  4. Schematic Design, Area Plans, and Floor Plans
    By bleonard in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-02-14, 06:51 PM
  5. Printing Plans on 2 different sheets
    By msg4amer in forum Revit Architecture - General
    Last Post: 2004-06-09, 06:27 PM
