Results 1 to 10 of 15
Thread: Create Layer name using the Drawing name
    2008-06
    39
    Default Create Layer name using the Drawing name
    Is it possible to create a layer using the drawing name minus the .dwg extension? I want to create a lisp file that automatically sets the layer name to drawing name with an X- in front of it.
    2005-01
    42
    Default Re: Create Layer name using the Drawing name
    Hi-
    Here is a quick tool that will create a layer using the drawing name with the prefix of "X-".
    (defun c:dwglayer ()
    (setq lay (strcat "X-" (vl-filename-base (getvar "dwgname"))))
    (command "layer" "m" lay "")
    Hope this helps.
    2008-06
    39
    That works but can I make it obtain the Referenced file name as oppose to the current drawing name?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Quote Originally Posted by g_wong View Post
    So you are referring to creating a layer based on an xref or referenced drawing?
    2008-06
    39
    Yeah that is what I want to accomplish.
    2005-01
    42
    Is there more than one xref?
    2008-06
    39
    The company standards are to create one layer per XREF, this takes quite a bit of time so if there is someway to automate it thru a lisp command that would be fantastic.
    2005-01
    42
    Give this a try.
    (defun c:dwglayer (/ lay)
    (vlax-for item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
      (if (= (vla-get-isxref item) ':vlax-true)
        (progn
          (setq lay (strcat "X-" (vla-get-name item)))
    (princ)
    2005-09
    Canada
    214
    Quote Originally Posted by jsowinski View Post
    Hi-
    Hope this helps.
    Never forget to Undescore AutoCAd command....
    (command "._layer" "_m" lay "")
    and many add condition if layer exist...
    (defun c:dwglayer (/ LayerName)
    (setq LayerName (strcat "X-" (vl-filename-base (getvar "dwgname"))))
    (if (not (tblsearch "LAYER" (strcase LayerName)))
    (vla-Add (vla-get-Layers (vla-get-ActiveDocument (vlax-get-Acad-Object))) LayerName)
    2002-01
    jUSt Here (a lot)
    9,105
    Typically, are your reference drawing names the same as the filename? Or does your company rename the reference name to a more common name?
  1. LISP to create layer, hatch and set layer back to original.
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2013-12-11, 07:22 PM
  2. Ability to Create a Layer that Acts Similar to Layer 0
    Last Post: 2008-05-28, 06:58 PM
  3. Replies: 3
    Last Post: 2007-03-14, 01:33 PM
  4. Replies: 2
    Last Post: 2006-05-10, 06:38 PM
  5. Replies: 19
    Last Post: 2006-02-12, 11:06 PM
