Results 1 to 6 of 6
Thread: converting IGES files
    2007-01
    6
    Default converting IGES files
    Once I have converted an IGES file into invetor as a part, Is It possible to edit and make changes to the models size, shape, and add features to it? The problem I am having is that inventor sees it as a surface (has no volume/thickness) and therefore to add holes and alter the shape does not work, like a normal part. I have used the thicken/offset command to give it volume and once done, it wont allow me to add sketches to that surface to extrude, sweep, ect. If anyone has any input that would be sweet.
    0,0,0 The Origin
    8,570
    Default Re: converting IGES files
    Shouldn't this and your other post be in an Inventor-related forum?
    2011-06
    2
    Quote Originally Posted by Bowen_lee2 View Post
    Me too waiting for the similar thing ! lets see if anyone finds solution to our problem
    2002-10
    Pflugerville Texas
    41
    Try using the feature reconizer (sp), this will convert the object to a solid and allow editing.
    2015-12
    293
    Can you post it?
    Williamsport, PA
    641
    Quote Originally Posted by David Gaskill View Post
    Can you post example of this?
    Feature Recognition will not convert surface to solid.
    Several years ago I did a presentation on how to fix IGES files in Inventor to form solids at AU, but it is no longer posted on the AU website.
    Send me an email and indicate what version of Inventor you are using.
    In short, yes you can get it to a solid (usually) and fully editable.
    Sometimes it is a simple Options setting, sometimes a bit more.
    If you can attach the original IGES file here it might be simple problem.
    If you want to learn to do it yourself you will need to become familiar with importing Options, Construction Environment (Repair Environment in later releases).
  1. Converting DWG to either IGES or STEP files
    By antoine.autruffe780653 in forum AutoCAD General
    Last Post: 2012-01-20, 09:27 PM
  2. Converting DWG to either IGES or STEP files
    By LA_Girl in forum AutoCAD General
    Last Post: 2009-08-24, 06:52 PM
  3. IGES files in Inventor
    By vagabond1066 in forum Inventor - General
    Last Post: 2008-01-05, 12:43 AM
  4. Saving iges files
    By jshotwel127293 in forum Inventor - General
    Last Post: 2007-01-11, 12:44 AM
  5. .stp files or IGES files Question
    By tc3dcad60731 in forum Inventor - General
    Last Post: 2006-07-06, 09:15 PM
