Thread: AutoCADLT 2008 Printing Problem
    2008-06
    3
    Default AutoCADLT 2008 Printing Problem
    The user's machine started giving them an "Notice" dialog box that stated "You do not have rights to print the secured document." whenever they tried to print or select anything to change in the print dialog box. Even though the file can be opened on other machines that have AutoCADLT 2008 installed on them. We completed a reinstall of AutoCADLT from thru the control program add remove progam system, but the problem still continues to be there. We also had another user log on to the machine and try to print and received the same notice problem. Our next step is to completely uninstall AutoCAD LT from the computer and re-install but if that is not required we would prefer not to be that drastic. Any help or suggestions with this problem would be appreciated.
    Earth
    9,819
    Default Re: AutoCADLT 2008 Printing Problem
    Quote Originally Posted by jss191 View Post
    ... an "Notice" dialog box that stated "You do not have rights to print the secured document." whenever they tried to print or select anything to change in the print dialog box.
    Is that the actual message?
    R.K. McSwain | CAD Panacea |
    2008-06
    3
    Yes that is the actual message that was given in the dialog box? Have you ever heard of someone seeing this message. It is very confusing as to what could be the problem.
    0,0,0 The Origin
    8,570
    That doesn't sound like an AutoCAD message. Could Cadlock (or Adobe? ) or other digital rights software be involved?
    2008-06
    3
    I do not believe it is a digital rights problem, since the exact same file can be opened up on other useres machines and printed out without any problems at all. Any other suggestions would be welcomed.
  1. Xref issues AutoCADLT 2012 converting to R14
    By david2011 in forum AutoCAD LT - General
    Last Post: 2011-11-29, 02:09 PM
  2. Any problems loading AutoCAD 2006 on a computer w/AutoCADLT 2008
    By jmmacari in forum CAD Management - General
    Last Post: 2008-07-07, 03:15 PM
  3. autocadlt 2008 and map3d 2004
    By gisdude in forum AutoCAD Map 3D - General
    Last Post: 2008-02-01, 10:20 PM
  4. 2008 Printing solid fill - Tip
    By mwiggins121466 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-08-31, 07:36 PM
  5. error starting AutoCADLT 2005
    By iffans in forum AutoCAD LT - General
    Last Post: 2005-03-08, 07:54 AM
