Thread: plan view from copy/monitor level
    2007-09
    Raleigh NC
    755
    Default plan view from copy/monitor level
    I did my framing on a level in my file. When I copied the levels in from Arch I moved the framing to that level and erased mine, and the associated plan. How do I create plans for the copied levels? Thanks.
    2006-01
    4,516
    Default Re: plan view from copy/monitor level
    View > New > Floor Plan. If you dont see the Level you want in the list, uncheck the "Do not duplicate views" button, and it should show up. Select the right level and hit okay, and you should go to the new Floor Plan...
  1. 2014: Vertical brace-Associated level to plan view-Not Showing
    By Ampersand in forum Revit Structure - General
    Last Post: 2013-08-19, 06:27 PM
  2. I can't get copy monitor to copy steel!
    By bwiersema in forum Revit Architecture - General
    Last Post: 2010-05-18, 07:53 PM
  3. 1024 Monitor Defined View, 1280 Monitor Render
    By rbdome in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-09-07, 02:44 AM
  4. Varying Floor Level Plan View
    By artitech in forum Revit Architecture - General
    Last Post: 2005-07-02, 12:18 PM
  5. Copy from Plan to Drafting view
    By DaveP in forum Revit Architecture - General
    Last Post: 2004-10-07, 02:21 PM
