Thread: Portable License Tool - Same computer
    I could stop if I wanted to Matt Brennan's Avatar
    2005-02
    Vancouver, B.C. Canada
    281
    Default Portable License Tool - Same computer
    Hi Everyone,
    I have looked and searched through the site but I haven't found what I am looking for. We are reformatting 20 computers in the office in which all the licenses are standalone. So rather than try to re-authorize each license, I know I can transfer the license file to the server and back to the reformatted computer using the Portable License Utility.
    I tried it on my home computer; exported the licensee to a file using the PLU, and then tried to import it into the same computer after being reformatted. In the end the license became broken in which I had to contact Autodesk for another license.
    When doing this, what is the step by step procedure in order to make this work.
    Thanks in advance,
    Earth
    9,804
    Default Re: Portable License Tool - Same computer
    PLU just doesn't work about 1/2 of the time for some reason - we gave up on it.
    Is your current licensing standalone, where each license has a different S/N, or MSSA (Multi-seat Stand Alone), where each license has the same S/N?
    If the latter, then you should be able to get a code automatically from Autodesk (using online activation...), otherwise, I would just get a new auth code from Autodesk for each license - and then consider moving to MSSA....
    R.K. McSwain | CAD Panacea |
  1. Recovering the portable license from a crashed computer?
    By ajzoch in forum CAD Management - General
    Last Post: 2009-10-12, 05:20 PM
  2. Portable License Utility
    By nat in forum Revit Architecture - General
    Last Post: 2007-08-08, 08:27 PM
  3. Portable License Utility
    By jyamasaki in forum Revit Architecture - General
    Last Post: 2005-12-14, 01:54 AM
  4. Portable license utitliy
    By krichison1 in forum AutoCAD General
    Last Post: 2005-05-20, 04:23 AM
  5. Portable license utility
    By wimmerea in forum CAD Management - General
    Last Post: 2005-01-21, 06:08 PM
