Thread: Design Checks
    2009-01
    Butler, PA
    8
    Default Design Checks
    After creating a design check for a profile. I am not seeing an exclamation point for the failed VC. Is there a setting to display the exclamation point? Please keep in mind that I'm refering to a Design Check not the Design Criteria File.
    I'm also seeing weird behavior where the exclamation point is displaying in the Profile Grid View on the wrong PVI No.. The PVI before the PVI with the exclamation point is the actual PVI point with the wrong Length of Curve. Once I correct the PVI with the wrong Length of Curve the exclamation point on the next PVI goes away. What's also weird is I have the Design Check set to Sag Curves Only and the exclamation point is showing on a Crest Curve in the Profile Grid View. See attachments.
    Finally, the same behavior appears in the Profile Layout Parameters except the exclamation point only display on the PVI with the wrong length of curve if I select the following PVI first.
    Anybody have any ideas why this happening or is this by design?
    Thx for your time.
    Pat
    2007-08
    94
    Default Re: Design Checks
    Check to see if the "Use design check file" selected in the profile properties. It may be checking it against the AASHTO file as well as the design check criteria you created.
    2009-01
    Butler, PA
    8
    The "Use design check file" is not checked. Good thought though.
    Pat
  1. 2012: Issues with Fillets, snaps, dimnesion checks
    By mroth3270139 in forum AutoCAD General
    Last Post: 2012-02-06, 09:42 PM
  2. rs2010 consistency checks
    By 777rivendell in forum Revit Structure - General
    Last Post: 2010-01-14, 05:54 AM
  3. Electrical and Interference Checks
    By jwongmep in forum Revit MEP - General
    Last Post: 2008-05-30, 09:10 PM
  4. Clearance for Interference Checks in Families
    By Tyveka in forum Revit Architecture - General
    Last Post: 2008-04-11, 06:53 PM
  5. Interference Checks with Pipes in 2007
    By melanie.santer in forum Civil 3D Tips & Tricks
    Last Post: 2006-08-03, 04:49 PM
