Thread: Smart block profile trace routine
    2008-07
    4
    Default Smart block profile trace routine
    I have a simple architectural floor plan drawing containing walls, door swings, windows and furniture symbols. The furniture, however, is made of multiple smart blocks that are comprised of wblocks with critical attributes and specific information by multiple vendors.
    I would like to develop a VBA routine that will allow me to capture the plan view profiles of existing furniture blocks from an AutoCAD drawing without capturing/retaining the attribute information. (Only interested in the 2D profile of the furniture blocks I would also like to copy the image to clipboard so that I can paste the image into a different AutoCAD drawing.
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: Smart block profile trace routine
    Quote Originally Posted by anj1 View Post
    Welcome to AUGI...!! You will find a lot of helpful people around here. But your post doesn't clearly mention what kind of help you are expecting from us. Could you be more specific please?
    2008-07
    4
    Okay, so what I’m looking for is a VBA code that will capture or trace the 2D profile (plan view image) of multiple blocks to a drawing selection set and that will Copyclip the selection set to the clipboard all in one operation. Because the selection set will consist of various smart blocks with tons of attributes, the capture or trace function shell only capture the objects plan view outline and not the attribute information itself.
    2005-02
    506
    The chances of getting a full application code is very rare here (Unless somebody here has enough time and patience for that). You have to take initiative for the coding and then others will be ready to correct your mistakes. By doing so, you will not only get your requirement accomplished, but also learn alot of new things in VBA, the latter being the main objective of these forums.
  1. BD23-4L: Block-to-Smart-Part Conversion Party!
    By Autodesk University in forum Building Design
    Last Post: 2013-04-08, 08:46 PM
  2. mullion profile / Cad import and trace
    By victim_ in forum Revit Architecture - General
    Last Post: 2009-10-08, 02:28 PM
  3. one selection block routine?
    By voigtmark in forum AutoLISP
    Last Post: 2007-07-27, 05:59 PM
  4. Help with simplifying Block routine
    By ReachAndre in forum AutoLISP
    Last Post: 2007-02-10, 03:40 PM
  5. Looking for a Block capture routine
    By BCrouse in forum AutoLISP
    Last Post: 2006-09-03, 12:07 PM
