Thread: Tips & Tricks - Revit Architecture
    Count (Formula) dbaldacchino's Avatar
    2005-07
    Missouri City, Texas (Houston area)
    3,250
    Default Tips & Tricks - Revit Architecture
    Hello all!
    As your new Tips & Tricks forum manager, I decided to start a thread in an effort to consolidate some of the most new useful T&T that are posted on the Revit forums (this one is specifically for Revit Architecture). If you see something worthy of making this list, feel free to send me a PM with a link and I'll post it here.
    2005-07
    3,250
    Default Re: Tips & Tricks - Revit Architecture
    This tip is brought to you by Scott Brown in this thread. Some might have heard similar suggestions by Phil Read at one of his legendary AU classes. Simply use a basic wall and apply a material with a surface pattern that represents the mullion spacing desired. This allows you to quickly go through several design iterations and keep your model light and snappy. Once design progresses, you can then change this wall to a curtain wall and locate grids, mullions and panels accordingly.
  1. Replies: 0
    Last Post: 2015-08-07, 05:30 PM
  2. Replies: 0
    Last Post: 2015-08-07, 03:47 PM
  3. AB318-3: Autodesk® Revit® Architecture Tips and Tricks
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2014-11-30, 01:02 PM
  4. Revit Tips & Tricks
    By dbaldacchino in forum Revit Structure - Tips & Tricks
    Last Post: 2008-12-23, 03:52 PM
  5. Revit Tips & Tricks
    By dbaldacchino in forum Revit MEP - Tips & Tricks
