Thread: Groups & Schedules - Natural Enemies
    2007-11
    37
    Default Groups & Schedules - Natural Enemies
    We're running into a problem in our projects and it involves the use of Groups and how they react to schedules. We have floors that are identical, therefore an efficient response is making them a group. This is also the same for ceilings. However, when we want to assign information to these groups, we cannot directly edit the schedule and are reduced to opening each group and updating said information. The real seriousness of the problem comes from when we want to update the same information on the same objects, such as doors. Unclicking "Itemize every instance" allows us to quickly do that, but the whole "You can't do that it's a group" error raises it's ugly head with the friendly "Ungroup" message as a viable solution.
    Is there a better way of having both flexibility and efficiency with Groups & Schedules I'm missing somewhere?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Groups & Schedules - Natural Enemies
    You have to select the group and edit it, update the schedule information, then finish the group. Yes this is a pain but it actually makes sense since groups are by definition supposed to be the same.
    Scott D. Brown, AIA
    BECK
    Pittsburgh, PA USA
    1,906
    Also, the Door Mark (Door Number) in Revit 2009 is "exposed" so you can number the doors without editing the group, provided you are using the built-in door mark parameters. All other door parameters, including any instance parameters you've added, are only available by editing the Group
  1. 2013 Natural Ventilation
    By KGC in forum Green Building Studio - General
    Last Post: 2013-09-05, 04:30 PM
  2. Schedules with heading groups
    By timsea81 in forum Revit MEP - General
    Last Post: 2009-05-29, 03:02 PM
  3. Cross Reference Key Schedules for Finishes / Finish Groups
    By saeborne in forum Revit Architecture - General
    Last Post: 2009-01-13, 03:57 AM
  4. groups and schedules....
    By rupertv in forum Revit Architecture - General
    Last Post: 2008-08-27, 09:00 AM
  5. Parameter Groups in Schedules
    By Gene Herring in forum Revit Architecture - General
    Last Post: 2005-07-06, 06:05 PM
