I just opened ACAD, and the only pulldown menu displayed is the Express pulldown. Is there a setting or command to bring back the rest?
try to restore your workspace, or one of the workspaces within the pull down. If this doesnt work, you should be able to use the cui to modify your workspace to include the other menus,
Hi,
Go into CUI and click on desired workspace. Then, on the bottom of the right side, you should see all the display properties of that workspace...make sure "menu bar" is "on" and you should be good to go.
HTH,
Alan
Thanks, y'all.
I switched to another workspace -- in this case, from AutoCAD Classic to 3D Modeling and back. I got the pulldowns back, but all my menu bars and flyouts were reset. I spent a little time this morning setting my screen back to the way I like it.
