Thread: BVSTATE - visibility state manager in block editor not working
    2007-10
    5
    Default BVSTATE - visibility state manager in block editor not working
    I'm trying to create a new visibility state in a block and the button to get the visibility states manager up (in the block editor) is not working. Typing bvstate on the command line does not work either. It just hangs until I hit ESC.
    I tried editing an existing block with some visibility states already defined and it does not work there either.
    Anyone experience this?
    2004-08
    Iron Station, NC
    3,197
    Default Re: BVSTATE - visibility state manager in block editor not working
    Quote Originally Posted by skivell View Post
    is it possible that the dialog could be showing off screen? you could try the Alt+space, M, then the arrow keys to see if that is the case.
    2007-10
    5
    You were right, it was hiding offscreen. Thanks for the help!
    2009-07
    Canada
    2
    Talking Re: BVSTATE - visibility state manager in block editor not working
    Quote Originally Posted by ccowgill View Post
    Thank-you! You solved my problem also. BAD WINDOWS!
  1. Replies: 1
    Last Post: 2014-11-20, 12:27 AM
  2. Visibility State selection upon insert of block?
    By Mamma Jamma in forum Dynamic Blocks - Technical
    Last Post: 2010-09-01, 11:41 AM
  3. Changing a visibility state for a Dynamic Block
    By jahed.ali in forum AutoLISP
    Last Post: 2010-06-04, 05:28 AM
  4. Change the Visibility State of Attributes in a block
    By jdixon in forum Dynamic Blocks - Technical
    Last Post: 2006-03-15, 02:44 PM
  5. Accessing Dyn Block Current Visibility State
    By bowlingbrad in forum AutoLISP
    Last Post: 2005-11-14, 02:17 PM
