Results 1 to 10 of 10
Thread: Add tolerances to dimensions
    2004-07
    Detroit Michigan
    2,508
    Question Add tolerances to dimensions
    I want to make a lisp for creating tolerances as I use the same tolerances on
    a daily basis. I want to try my hand at creating the lisp myself (imagine that).
    I think I can do this......I will post my code when Im done. Question I have, is
    what variables are used for the Tolerance. I cant seem to find where the values
    for individual dimensions are stored. Please help.
    2000-01
    Seattle WA USA
    5,859
    Default Re: Add tolerances to dimensions
    The Properties palatte tells you the system variable names.
    2004-07
    Detroit Michigan
    2,508
    Thanks, I see it, Dimtol, Dimlim, etc.
    2004-07
    Detroit Michigan
    2,508
    Here is what I have:
    (defun c:T2 ()
    (command "dimtol" "on")
    (command "dimtm" "2")
    (command "dimtp" "2")
    (command "dim" "update" pause)
    (command "dimtol" "off")
    (princ)
    This works, however, it does not set dimtol back to off......
    Can somebody show me how to do that????
    Active Member tuomo.jarvinen's Avatar
    2015-09
    Jyväskylä, Finland
    53
    How about:
    (defun c:T2 ()
    (command "dim" "update" pause "" "exit")
    (princ)
    2004-07
    Detroit Michigan
    2,508
    That doesn't quite work either.....rather than pause for user input, it is
    trying to enter dimtol when you are supose to pick the dimension.
    Maybe a better version would select the dimension first and then ask for
    a tolerance variable which will then be passed to the dimension.
    Help??? Im lost with this...
    defun c:T2 ()
    (setq D (ssget :s)
    tolerance (getreal "tolerance:")
    (command "dimtm" tolerance "")
    (command "dimtp" tolerance "")
    (command "dim" "update" "D" "")
    (princ)
    13,657
    Hi
    Why not simply modify the DimAddRef one from an earlier thread...
    Add text "REF" to dimensions
    (defun c:DimTolerance (/ Save_DimTol Save_DimTm Save_DimTp DimObject)
      (setq Save_DimTol (getvar "DimTol"))
      (setq Save_DimTm (getvar "DimTm"))
      (setq Save_DimTp (getvar "DimTp"))
      (setvar "DimTol" 1)
      (setvar "DimTm" 2)
      (setvar "DimTp" 2)
      (princ "\nSelect Dimension to add Tolerance to: ")
      (setq DimObject (ssget '((0 . "DIMENSION"))))
      (if DimObject
    	(command "._-DimStyle" "_A" DimObject "")
      (setvar "DimTol" Save_DimTol)
      (setvar "DimTm" Save_DimTm)
      (setvar "DimTp" Save_DimTp)
      (princ)
    Have a good one, Mike
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    rhall, do not give up ! Try this :
    (defun c:T2 ( )
      (command "dimtol" "on" )
      (command "dimtm" "2" )
      (command "dimtp" "2" )
      (princ "\nSelect objects : " )
      (command "-dimstyle" "a"
        (while (= (getvar "CMDACTIVE") 1 ) (command pause) )
      (command "dimtol" "off" )
      (princ)
    : ) Happy Computing !
    kennet
    2004-07
    Detroit Michigan
    2,508
    I thought about adding it as a dim overide which would be easiest....most of my drawings have been created with symetrical tolerances so it would not work.
    Both of these routines work great, thanks a bunch.
    So in Mike's the current variables are saved and then reset??
    I will have to try that in some of my other routines.
    In the other lisp, I am still unsure what CMD does??
    2002-05
    1,707
    Hi again rhall,
    In a lisp there You are running for example the command pline, You do not know how many vertex the user is going to insert. Instead of typing pause pause pause how many times ? CMDACTIVE can check if the command pline is still active, and do a pause for the next users input. If the command pline is not more active the next line in the lisp will continue. CMDACTIVE can identify if an ordinary command, transparent command, script, lisp or a dialog box is active. It is very useful when You do not know how many user input You have to expect. You can use it with "while"or "if" statement. Please see the help file [F1].
    If You are using a lot of "dim override" I am strongly recommended You to create a second dimensionstyle, You can mess up a drawing in regeneration time with half an hour or more ( I have tested examples with both kind of dimension styles in AutoCAD 2002 ), and I suppose that AutoCAD only do like a small amount of "dim overrides". So why not use a second dimensionstyle when it is so easy to afterwords use the "brush" _matchprop to change from one dimensionstyle to an other, or set the right dimensionstyle before dimensioning. Time is money ; )
    : ) Happy computing !
    kennet
  1. 2013: Export DWG tolerances
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2014-03-10, 05:37 PM
  2. Variable precision and tolerances in dimensions
    Last Post: 2013-12-14, 05:11 AM
  3. Tolerances Controlled by Holes Tolerances.xls
    Last Post: 2006-05-06, 04:24 AM
  4. Constraints with Tolerances
    Last Post: 2006-04-12, 05:03 AM
  5. Replies: 3
    Last Post: 2006-01-23, 07:13 PM
