So i've installed Revit 2009 and the Render Library says it's not available. Yet when I go to the Option Box the Path is there under the Rendering Tab. I've uninstalled and reinstalled it several times. What's else should I try?
C:\Program Files\Revit Architecture 2009\Data\Rendering
do you have content here? If not, something is not installed correctly.
cheers
Are you sure you have the file called assetlibrary_base.fbx under C:\Program Files\Revit Architecture 2009\Data\Rendering\?
If not you can download the ProteinMaterialLibrary.cab file from the following link:
http://revit.downloads.autodesk.com/...ialLibrary.cab
Extract the content from the file and you will find all you need there.
Andre Carvalho
Hmm... Are you using Windows Vista or XP? Do you have administrator rights on your computer? Have you tried starting Revit by right clicking the icon and selecting "Run as Administrator"? Sometimes functions that are installed, like extensions only show if you start Revit by running as administrator, even if you are the Administrator...
Andre Carvalho
What processor are you using? The renderer requires a processor with the SSE3 instruction set. Sounds like you may have an older AMD processor. Only the newer ones have the SSE3 set. My old home pc had the same problem. It had an AMD Athlon XP. I couldn't render with that computer.
CJ
