H'Angus
I looked at this earlier and came to the same conclusion, also the circular window has the frame turned on, but you can turn it off to look like your line sketch if you want.
Dan, I haven't played around much with this, can the windows/doors use an override cut plane rather than matching the container (ie the wall). What if you had windows at several different heights where a cut plane wouldn't pick them all up, some above some below, some in between. If that makes sense?
